1 - 20 of 23 Posts
I have a 2008 Cobalt 2.2. I just installed a ZZP Catless Downpipe. I bought a fouler for the O2. It took two days for my CEL to come on after install. So I went to auto zone and they could not find any info on this codeP013F. Anyone known a way to fix this issue and will it cause performance issues?
P013F - Generic
TypePowertrain - Fuel and Air Metering - ISO/SAE Controlled
Description
O2 Sensor Delayed Response - Lean to Rich
LocationBank 1 Sensor 2
---------- Post added at 06:09 PM ---------- Previous post was at 06:08 PM ----------
I believe that's your downstream sensor getting that reading, not to good with my engine stuff. One of the awesome engine guys will help you here
Sometimes de-foulers don't work.
I do have an exhaust leak were the header and downpipe connect. I'm having a hard time to get this leak sealed. Would this exhaust leak have something to do with it. But it is the Bank 1 sensor 2 right?
Yes sir.
I would remove defouler, replace O2 sensor and get tune. Worst case senario Vince will have to turn off the data relay from that sensor so you dont get the check engine light.
1 - 20 of 23 Posts
