Hey guys I was wondering if y'all have any technical specs on the cooling system for cobalts. Specifically, what I am looking for is the radiator size, radiator coolant capacity, radiator fan CFM, and what stages the fan can run at (two speed, three speed, etc.).
Here are the specifications.
The ECM commands Low Speed Fans ON under the following conditions:
• Engine coolant temperature (ECT) exceeds approximately 106°C (223°F).
• A/C refrigerant pressure exceeds 1 310 kPa (190 psi).
• After the vehicle is shut off, the ECT at key-off is greater than 140°C (284°F) and system voltage is more than 12 volts. The fans will stay on for approximately 3 minutes.
The ECM commands High Speed Fans ON under the following conditions:
• ECT reaches 110°C (230°F).
• A/C refrigerant pressure exceeds 1 655 kPa (240 psi).
• When certain DTCs set
