1 - 11 of 11 Posts
I am looking to replace the stock cluster bulbs with colored LED's to color the gauges . Chevy told me the cluster was "non-serviceable." Any one know the size of the bulbs in the cluster? Thank you.
They are all 12 volt bulbs. as far as size here's one.
Here is the difference between a bulb and a 5mm LED.
If you don't want the light to come out from the tip of the LED just grind or file it flat. This forces the light to come out the sides and avoids a bright spot.
They are called twin leads and are probably close to the same as the ones you find in a dash wedge bulb. I can give you a part number for the LEDs if I can find it. Ordered mine from....
12 Volt LED
anyone have pictures of the inside of the cluster? I'd like to make mine light up red like my friend's g5
I think Acoutu has a thread on here with pictures.
1 - 11 of 11 Posts
