1 - 13 of 13 Posts
Alright So I moved From Miami To Canada and they require cars to have daytime running light which will cost me 300 dollars. All they do is add a Module thing I want to do if I can do it myself.
Or just check your DRL fuse, it may be blown. I noticed when I was setting up my new HID setup it was burned out. I have to replace it. Check your fuse box under your hood. There should be a spot under the cover that shows where it's at. If you still can't find it. There is a picture on Buyhid.com home that shows where it is in a how-to. It's a red 10 amp fuse.
If you are running HID's and didn't remove it when you installed them, I believe it will blow the fuse. That'd be the first spot I'd check. IT's just a small red 10 amp fuse above the fuel pump one. Use a set of pilers and you can pull it out to check it.
1 - 13 of 13 Posts
