1 - 9 of 9 Posts
I doubt it is the fuse if the lights are flickering. Check the connections and make sure no wires are loose. I don't know a whole lot about HIDs but maybe check the ballast.?
---------- Post added at 02:42 PM ---------- Previous post was at 02:42 PM ----------
How long have you had the bulbs?
It will do that if you don't shorten the DRL loop or bypass it with a relay. Best to pull the fuse for now so you don't fry your ballast. But you won't have any DRLs
What do you mean it's not there or it's hiding behind the fuel pump relay?
Wait now you have a 2005, so DRLs are the amber lenses. If your ballast is flickering it isn't because of the DRLs
What brand are you using and do you have the harness with it's own power and ground and then the old plug only supplies the information of when to turn on. I don't have any issues running mine as DRL lights.
1 - 9 of 9 Posts
