1 - 15 of 15 Posts
Has anyone used this site before? I purchased the Chevy Cobalt LED Kit which includes a dome light, trunk light, and license plate light that come in many colors. They have HID headlights but I'm not sure what I need to make sure they work... Do I want my "bulb size" to be Halogen Hi or BiXenon, and what is the difference? And, do I need the HID relay? The link is here but you may have to enter car information (i.e. Chevrolet > Cobalt > 2010). Thanks!
I've never used that site. I got mine elsewhere. If you have stock headlights make sure you get a set for 9007 bulbs/connector. It also means you'll want the 9007 bulbs to go in it. I'd also recommend using the BiXenon in stock headlights so you retain hi-beams. You'll be happier with the output. It is not required to get the relay but it is also HIGHLY recommended as well. If you have aftermarket headlights, well...match the lights you currently have. I have Gen3 halo/projectors and use H1 bulbs. Factory fog lights are H11 bulbs, so for those you'll need an H11 variety.
To answer your question about the difference in bulb types, here is what their site says about it.
http://www.diodedynamics.com/service/index.php?/Knowledgebase/Article/View/42/5/what-are-halogen-hi-and-bixenon-hids said:
What are Halogen Hi and BiXenon HIDs?
Posted by Paul Diode Dynamics on 27 February 2012 12:18 PM
Some vehicles use dual-filment bulb in one headlight housing. This allows for the high beam and low beam to be in one socket. Some dual-filament bulb sizes are 9003, 9004, 9007, 9008, H4, and H13.
To convert these to HID, we have two options. First, we have halogen Hi bulbs. These use an HID low beam, like a normal HID Conversion, but also hae a small halogen bulb to create the high beam. These are quite efficient, and are just $5 more than a regular single-beam HID kit.
We also have BiXenon HID Kits. These come with a harness, which is needed to control the bulb function. Just like on many vehicls with OEM HIDs, the HID bulb is moved by the harness in order to create high beam HIDs when needed, and then moves back into position to angel the light back down for low beam HIDs. The result is HID high beam and HID low beam, all in one bulb. Due to the electronics needed, this is $40 more than a regular single-beam HID kit.
If you have further questions, please don't hesitate to contact us!
I hope that answered your questions. If not, ask for clarification or additional info and someone will help! Good luck!
I do have stock headlights as of now...so I should get the BiXenon and the relay harness? What does the relay harness do?
The relay I believe is to avoid applying low voltage to the ballast in DRL mode, but I find just shorting the purple DRL resistor wire would work just as well.
It seems like getting the harness is just a little safer, and for $10 probably not a bad addition. Would the kit then just be new bulbs that would have to be put it and connected? ...I don't really know anything about wiring a car, but I can't imagine this would be hard?
If you want to make it easy just go with buyhid.com and get a set that has been retrofitted for HID's. Plus, HID's in stock housing equals pissed off people in front of you. You want to get new housing with projectors or install projectors in the stock housing.
A buddy of mine recently installed LEDs in his Cobalt (plate and trunk). Now I'm totally sold on the idea. Besides looking good, the trunk light provides more light than the stock bulb that was there. I've been looking at what different vendors have to offer this week. Of course they all say that they have the best, brightest ect... I don't think all LEDs are created equal so... is there anything special to look for when purchasing these bulbs. Also, after seeing the color of the plate bulb, some 6000k hids would be a nice match!
Oh and one other thing, the site that the OP lists above, they list LED fog light bulbs. Never thought about using them in the fogs. What do you think?
I would get HID's only becuase I already have 6k in the headlight housing. I used cheapo LED's from china for my trunk and plate lights and it matches wonderfully. Now I need to get LED reverse bulbs and 3rd brake light to complete the deal. Still undecided what I am going to do about the side markers. Might just find a black car and cut the metal out to fit the side marker holes and try making it flush up.
Looking at map lights. Do people usually go with the 360 degree or stick style as seen here?
The LEDs that I've seen kind of have a blue tint but I believe they are listed as white. Pictures that I've seen of LEDs that are blue, are a deeper blue correct?
Discussion Starter #11
Massguy and Blackbalts...
I bought LEDs from Diode Dynamics. They have a license plate/dome light/trunk light package that was about 20-25 dollars, you can get a little bit brighter ones for more. They also sell colors....I think blue, yellow, red, and a few more...I stuck with white and I like them. Much brighter than stock and not expensive. I got the stage 2 kit for brightness
Sent from my iPhone using Autoguide
Discussion Starter #12
My trunk light is 360, and the dome was a flat piece, the license plate like has two bulbs on the tip I believe.
And yes, I got white but they do have a blue tint to them.
I dont have a dome light but I spent $6 on my trunk and liscense plate lights. Just sayin!
1 - 15 of 15 Posts
