1 - 20 of 69 Posts
TOOLS NEEDED
10MM RATCHET WRENCH
13MM DEEP SOCKET
14MM DEEP SOCKET & BOX END WRENCH
15MM DEEP SOCKET
13MM SOCKET & OPEN BOX END WRENCH
15MM SOCKET & OPEN BOX END WRENCH
JACK AND STANDS, OR RAMPS (or a car lift if your lucky)
RATCHET AND 6" & 3" EXTENSION
FLASHLIGHT
PENETRATING FLUID
O2 SENSOR SOCKET, OR 7/8 BOX END WRENCH
Estimated time for install: 1.5-3 hours
(Step 1)
Jack up the car and put on jack stands and make sure care is secure. Let the car cool down. (If you have a strut bar, this is a good time to remove it. Makes install much easier)
(Step 2)
Remove top and bottom heat shields. (Top = 3 13MM bolts) (Bottom = 1 15MM bolt & 10MM bolt) Remove the 10mm bolt from the top.
(Bottom = 1 15MM bolt & 10MM bolt) Remove the 10mm bolt from the top with a ratchet end wrench. (not a socket wrench)
(Top view for 10 mm bolt)
(Step 3)
Spray down all 10 bolts on the manifold, the 3 bolts on the manifold/downpipe and the 2 bolts on the downpipe/catback with penetrating fluid. (This will make this whole process much easier!)
(Step 4)
Unclip the oxygen sensors, The lower one is to the downpipe. THe upper one is to the manifold. (removing the downpipe makes this much easier, even if your just installing the header) Do not remove the sensor from the manifold yet. This will be done after the manifold is out.
(Step 5)
Remove the downpipe, Starting with the 2 rear 14MM bolts. You will need a wrench for the nut and the socket for the bolt.
Then use your 15 MM deep socket to remove the front 3 15MM nuts from the manifold/downpipe
Once you have the downpipe off the car, place it aside.
(Step 6)
Removing the manifold, There are 10, 13MM nuts holding on the manifold that need to be removed. All but the 3 middle bottom nuts can be removed from the top. The others are easier to remove from the bottom. The very middle bottom nut is a PITA! You will need a long extension and go at it above the manifold but still from under the car.
(Here is a pic that gives you an idea of the nuts to be removed. Sorry I do not have any pics with the stock manifold on)
The nut circled is the PITA one
Once all nuts are removed, remove stock manifold and gasket. Inspect the head to be sure the area is clean and there are no obstructions that could cause leaks. Here is a pic of the manifold removed. (Very restrictive)
(Step 7)
Installing the header, Place the new gasket and the header on the head bolts and finger tighten down all 10, of the 13MM nuts so the header sits in place like so.. (DO NOT USE ANY KIND OF GASKET SEALER!)
Then, working from the inside bolts to the outer bolts, tighten each 13MM nut tightly but not extremely tight. (Over tightening will squish the gasket causing leaks)
(Step 8 )
Remove oxygen sensor from the stock manifold, Using either an O2 sensor socket (A 7/8 deep socket with a slit down the side for the wires) or simply a 7/8 box end wrench. Next, take the sensor and screw it into the bung on the header. And give it just a little "snug" with the 7/8 wrench.
(If installing a new downpipe, Repeat this step for the O2 sensor on the downpipe.)
(STEP 9)
Installing the downpipe, This particular header came with 3 double threaded bolts and 3 nuts like so..
You will want to screw these bolts into the bottom flange of the header so there is only about 1/8 inch of threads before the middle non threaded part of the bolt.
Next, pair the downpipe and header flanges together along with the new gasket. Finger tighten on all 3 of the 15MM nuts onto the bolts, and then tighten them with a ratchet. (Do not over tighten!) Be sure there are threads exposed on both sides, the header and beyond the nuts like this.
Once those bolts are tightened on, the rear downpipe flange should be pretty much mated up with the flange for the rest of the exhaust. Reinstall the 2, 14MM bolts.
(Step 10) Remove the negative battery terminal, to reset the ECU. Reclip both sensors, and reinstall the bottom heat shield. The top heat shield will take a little hand bending and manipulating but it can be reinstalled also, with the exception of one bolt. After about 10 minutes or so, reconnect the negative battery terminal.
Now start the car and check for leaks. If there are none, Go rip down the street and enjoy your new header!
Discussion Starter #2
Alright its done! This took a long time to wright up!
Thanks admin! It took a lot of time! :shock: Then when i was almost done, I accidently closed the tab!
Very nice write up.
Thank you for taking the time to do this.
Can I add something?
According to the factory service manual -- under a warning...whenever you replace an HO2S sensor you must do an erase of the ECM through the OBDII port, even if you have no DTCs, to reset the sensor learn. Says you must do this or you can damage the sensor. While you may not have actually replaced your sensor, you did remove it and install it in a totally new part...just makes sense to do it since the factory says to.
Yeah, honestly I did unplug the negative battery cable while i install the heat shields. I'll add that!
Anything else I should add?
Did you remove your exhaust manifold from below the car and install the header also from below the car?
On my auto equipped 2.2 and 2.4 Cobalts I was able to swap out the original exhaust manifolds with the GMPP ext-honed manifolds from the engine compartment (between the VC and firewall) and did not have to remove the DP. Wonder if I can do the same with this header?
awesome write up. that header looks amazing.
I removed, and installed it from below the car. There is not much room between my valve cover and firewall. But with the automatics You may have enough room.
Thanks for the comments guys!
bumped for the new guy asking about header installs.
BTW this is the best header install how to I've ever seen. Very nice job. Folks this is how you make a how to. Lots of pics of exactly what you are working on.
Discussion Starter #12
Thanks IMA! that really means a lot to me! I spent a lot of time wrighting this up!
I say if this is your first time doing this allow 2 hours. It can certainly be done quicker but those bolts can be pretty stubborn.
Discussion Starter #18
Not completely necessary, But I would recommend it. One of the header tubes is awfully close to a coolant line.
oh I just remember, a friend of mine wraps a tape around the tubing to his turbo pipes. He told me it prevents the heat I think it's called heat shield tape or something. Would that work as well if the heat shield didn't work out?
Discussion Starter #20
Yeah, that is fine. Its called header wrap. Just be sure you clean the header up real well before you put it on. Otherwise it will corrode. Also be sure you put it on before the header gets hot the first time.
1 - 20 of 69 Posts
