1 - 8 of 8 Posts
Rear suspension only. Do (should) I need a spring compressor?
From reading here, all I need to do is loose the lower shock bolt. The control arm should come down, and the springs should come out.
Am I missing anything else?
TIA
Raise the back of the car and remove both shocks in order to remove the springs easier. Use a pry tool to stick under the plastic that's on the bottom of the spring and it'll pop out.
1 - 8 of 8 Posts
