1 - 20 of 23 Posts
Well i put the blue led light in the dome n have it come on when the car opens but when i close it n lock it it dems out but it doesnt look like its cutting off like its alil light going though but not seeable from outside but still power coming to it to glow alil..any idea?
The infamous afterglow. Some Cobalters have this problem some don't. I don't. Pretty sure it is caused by the LED (being a diode) rectifying standing waves on the open wire from dome to BCM. I haven't proven this yet because I haven't seen it yet, but many members complain about it.
Mine does it
Don't think it causes a problem, just annoying. When you turn it off you disconnect the wire so no more standing wave at the LEDs.
You make it sound like it's fully on? My dome LED has a extremely small afterglow
Sent from my PG86100
Maybe I don't get this problem because I installed a 47㎌ capacitor at each strip to filter the DC and to have a nice fade out when it turns "off"
Well i fades out fine but like u said that lil after glow thats really light that u cant see.
---------- Post added at 07:37 PM ---------- Previous post was at 07:37 PM ----------
Unless u look straight at it
---------- Post added at 09:17 PM ---------- Previous post was at 07:37 PM ----------
So to solve this afterglow should i use a load resistor or a 47uf capacitor how would i mount or put it onto this type of bulb?
I'm not even sure that's the reason mine don't glow, they just don't. But you could just solder the leads to the two loops at the end making sure positive to positive and so on.
Yes, and of it doesn't change anything for you, just clip it of.
Yep, if that's what you have. You got everything to gain and nothing to lose by trying.
yeah mine has a slight glow to it when i close my doors, but not to any degree that would affect battery life or perfomance. ive had mine for months and not once has my battery had any issues.
haha i can see that :p i would have told you about it when i suggested the bulb but i totally forgot it even did that
Just clip it on first to try, if it works then you can go through the other expenses of purchasing an iron an some solder and what not.
1 - 20 of 23 Posts
