the inside light in the middle of the two front seats. the switch came loose to adjust whether you want it off, door, or on or whatever, it came loose, so im wondering how do i take that off to put it back on track without breaking it? are there clips and if so where are they?
Just tore in my head liner....once remove the plastic lens cover It has 3 plastic clips 2 up front use a flat head screw driver on the clips should see the 2....back it just a matter a a slight pull backward.... the clips are in a triangle pattern...2 up in the bulb area and one in center of the back......can take pic if need mines out right now....
---------- Post added at 11:52 AM ---------- Previous post was at 11:50 AM ----------
More of hook then clip.......
