1 - 20 of 45 Posts
Im trying to figure out why my doors wont unlock when put my car in park and shut it off. I think it use to but never really noticed it till now. cause now i have to hit the unlock button to get out where before i didnt have to. anyone able to give me an Idea. the latches work and the handles are fine.
Have you had any trouble with getting the key out of the ignition as well? If so I would say it may be related the shift linkage and the car not thinking its fully in park. I had that problem a couple times after I had my trans serviced. Had to take it back and have the linkage adjusted. It also sounds like it could be something electrical. I would think it was a bad relay or fuse but if the unlock button still works then that may not be the case. I would have to look at a wiring diagram to see what is suppose to trigger the locks when putting the car into park
But there is a "PNP"(Park Neutral Position sensor) switch mounted on the transmission that signals to the BCM if it's in Park or Neutral.
Ah yes that sounds right. I bet there is something up with that sensor. I knew there had to be something that took a trans signal and told the BCM to unlock the doors
What year Cobalt or G5?
Before buying a new switch make sure this is your problem. You might just have a broken wire or dirty contact. GM part number for 2008 2LT is 24219476, there again verify with VIN to make sure.
I reset the car by disconnecting the battery, Its working now but question i have now is. is it only suppose to unlock the drivers door or the whole car???
The whole car I believe.
Whole car
Is it the Park Neutral Safety switch not triggering? Could be the solenoid not engaging.
or could also be parking paw too...I was referring to the switch, it should be either a relay or solenoid from the TCM. Are you getting a DTC or CEL? (Diagnostic Trouble Code or Check Engine Light)
Sorry im a bit late on that, the switch should automatically unlock all doors.
Next time it happens, disconnect battery and re-seat "P1" and "P2" on "BCM" module. I forget which one carries the gmlan from "TCM". It won't hurt to re-seat them both. Probably a buildup of corrosion.
Discussion Starter #18 (Edited)
Im not getting a check engine light I havent plugged in my tool to scan for codes. coby you got a diagram on where i can find the P1 P2 BCM? BUT would all doors unlock if theres no passenger in the front seat or would only the one drivers door?
Here circled in red is "P1" and "P2" is the similar connector to the left.
Discussion Starter #20
But the question I also have is would the door unlock work on all doors if there isnt a passenger in the vehicle.
1 - 20 of 45 Posts
