1 - 9 of 9 Posts
dose the INGALLS "STIFFY" Engine Damper, and the ZZP BILLET Trannie Mounts from cobalt-addiction.com fit on the 2.2 L enigne? with 5-speed manual?
the ingalls will fit. but there is a clearance issue with a k&n typhoon though. not sure about other intakes.
regarding the trani mounts, i took this directly from zzp'z website-"Works with all 5-speed manual transmission Cobalt/Ion applications. This product is not compatible with automatic transmissions! Some increase in cabin vibration will be present depending on driving conditions." :)
if you order, i would get directly from zzp. the cost is the same, but i have heard some not so good things about CA's customer service.
Yes they will fit the 2.2 with manual transmission. As long as you don't have a K&N or GMPP intake the ingalls will work. I would suggest just going with an engine mount like the ones from TTR
Discussion Starter · #4 ·
how exacally dose it not fit with a KN intake like the one I have? Is it possible to work around or modify pieces so it dose fit or no?
Heat sheild is in the way from what I have seen. I plan on doing it and either modifying the shield so it works or removing it.
Well you could cut the heat shield.. But its really not worth doing that.. Besides an engine mount is about the same cost, except works better!
Discussion Starter · #7 ·
was gona get both. what about the weapon R engine damper that mount in the same place? now im thinking of maybe not getting it and using the money for an exhaust instead. tsudo I think.
1 - 9 of 9 Posts
