Ok so I have an 07 ls with sai. Obviously I cant change the exhaust mani due to my sai. So I was curious, is their a down pipe that will fit my car without reflashing the ecu or throwin a cel? I assume I need one with a cat so that i am all legal.
You can try just about any aftermarket DP or even the LSJ DP.
Almost all the DPs for cobalts will work. As for cat or catless it depends on your state. If you have to pass emissions then you will need a cat, otherwise its your choice. If you go catless and want to avoid a CEL I suggest a 90* O2 Adapter for the sensor. I got one on ebay for around $20 and it works wonderfully.
