Hi I have a 2005 LS we purchased for my daughter, great car so far. I noticed the small storage bin on the driver side is not installed on the small hinge like it should be so the door is crooked. Does anyone know the trick for removing this bin and installing properly? Thank you
When pulling it out you will see a small tab on the right side. You have to squeeze it in for it to clear the panel and come out. once it is out you will see the hinges. the left side, is a male/female and on the right side there is the same female/male except there is a slot in the female to slide the male piece in sideways. you should be able to figure it out. hope this helps
Thanks Daman,
I really appreciate it, so I basically tilt it down so it can release? I will give it a try, I just did not want to break it
Thank you
