1 - 8 of 8 Posts
Hey! I'm new to these forums, but not new to them if you know what I mean, lol. I've always looked to them when I needed to fix my Cobalt, but I have now came across an issue to which I haven't seen a direct fix to. I have a lone DTC U2107 code in my car which states, Lost Communications with Body Control System and an issue I have seen is: No start no crank, unless jumped and then car doesn't last long before dying again, but battery and alternator is fine. Any suggestions on this? Thanks in advance!
Try re-seating connectors on the BCM a few times to clean any possible corrosion and flip fuse 26 ( ECM/TCM ) upper left corner. Check all 3 BCM fuses.
I'll try these as soon as I get home around 7 tonight. By re-seating the connectors on the BCM, are you referring to the blue L-like shaped connectors, and how should I go about cleaning them? Also, by flipping fuse 26, do you mean to just pull it out, turn it the opposite way, and to place it back in. Lastly, I've only seen 2 BCM fuses, which were under the hood, so where is the third one? Sorry for all of the questions, but I'm trying to make sure that I do these things correctly. Thanks again!
Well, Coby7, it actually took me until now to get to my car...been having a seriously busy time with other things, but I finally did. I didn't know how to take off the connectors, so I tried taking the BCM fuse in the trunk out and the ECM/TCM fuse out first and found out that the BCM fuse in the trunk was fine, but the ECM/TCM fuse was burned on the prongs, but it still had continuity via a multimeter and the wire wasn't broken either. Being concerned I took out another fuse by random and it was the exact same. Do you know what that could be from? Btw, jump started my car before I did this and my car didn't seem to have any issue, but I didn't try to drive it either. Wouldn't crank on its on afterward, but I checked the battery and it's dead.
Can anyone else help me with this?
Did you change your battery? Did you re-seat the connectors? Just pull the blue levers and the connectors will pull away. Disconnect battery first.
I haven't changed the battery because I was afraid of it going bad just like my current one did before I had this problem fixed. I'll try to re-seat the connectors soon and get a new battery as well. I'll post back once I can do this.
1 - 8 of 8 Posts
