I'm not 100% sure about this but i dont think you'll have to lift the engine. the oil pan should be held on by 10mm bolts(guessing size) around the outside of the pan just take all them out and the oil pan should pull off. you may need to pry it with a screw driver to break the seal. make sure you get a new gasket.
