I have a misfire on cylinder #3, It only happens after revving the engine really high then when I idle, it stops working. When I drive up to maybe 25 mp/h it kicks back in and I feel it jolt and is fine until I idle.
I have replaced spark plugs for all cylinders, and the coil pack for cylinder #3.
I went to a shop and they told me that it's not holding compression.
Does anyone know if compression actually could be the problem? I don't know cars that well but it just seems odd to me.
Chevy Cobalt 2008, 2.2L Engine
compression actually could be the problem.
What are the pressure reading for each cylinder? Each cylinder’s pressure could be different by a little but that should all be close. The difference should be no more than about 10psi between the highest and lowest.
