1 - 9 of 9 Posts
Hi all, sorry I have been a little busy with moving. I have 2 random issues.
1st Idol:
Before my idol was bouncing while coming to a stop and a throttle body and air filter clean all but solved that. Now with the weather and humidity I have turned the A/C on and voila its back! Only when the A/C runs..... Ideas?
2nd :
2days ago it.started. I turn they key, start assist kicks in, engine is turning but is struggling to fire. After second turn it finally kicks. Is this a symptom spark plugs, starter going, fuel pump? I just don't know and can't afford to replace it all. ;-)
Thanks guys and gals!
Sounds like you hit a bad batch of gasoline.
Start with the cheapest first, Spark plugs will run you under $40 under $30 if you shop around. If you are close to 100,000 miles you're due anyways.
Thanks T! I can always count on you! ;-)
Levee
Sea foam in the gas should help with that.
Oooo seafoam. That's a good idea Levi! Tonight for 32 bucks and a 10 gas card rebateI replaced the plugs. Fortunately I didn't screw this one up. Haha. But it still isn't firing properly. I will try seafoam in the tank tomorrow, budget depending.
If that doesn't solve it am I looking at coil pack replacement time?
Also, I am not sure I understand how any of this would help my idle jumping like a Mexican Jumping bean wwhen coming to a stop with the A/C running.
When A/C clutch is signaled to turn on the PCM also receives this signal. When it does it does two things It turns on fan 1 then it increments the throttle position actuator to compensate for the extra load on the engine and alternator.
Oh, so this is normal opposed to abnormal. Nice! Thank the lord! The the Coby7 master. I have happily but in a broke sense dumped a lot of money into this car. I can't wait till its 100%.
I have some tech data I would love to have analyzed. I'll post it up shortly. One mystery is cylinder 1 has had 2 misfires.
Before or after you changed the plugs?
Started back a few weeks ago. Not plug related. A/C related lo
1 - 9 of 9 Posts
