1 - 1 of 1 Posts
09 Cobalt LS 5sp. 287K miles. Engine won't crank. Disconnect battery for1/2 hour and it works again. This used to happen every 3 months or so. Now it happens more than once a day. Also, the first time this happened I jumped the starter and car started then shut down in a few second. This now happens with the key. Starts, then shuts down. Do this enough and you get home. Once runnung there is no issue. BCM? PCM?
1 - 1 of 1 Posts
