1 - 13 of 13 Posts
Okay so if you don't know, I'm learning as I go here, just so you know, I live in WV so we have to have a Catyltic Converter to pass inspection, so here's my question, If I was to go from the headers back (I have a 2.2 Auto) with the Racing Solutions Header/DP with the SRI, would a Tsudo just bolt up to the downpipe, or does it bolt to the catalytic convertor?
so basically does it goes like this \/
Header -> Downpipe -> Catback ->
or
Header -> Downpipe -> Catalytic -> Catback
I'm seriously asking this, NEWB question I know...
dude duffy thats a dumb question i believe it goes header downpipe, catalyic, than muff.. if im not mistaken. can call u my work phone or the cell phone
The catalytic converter is apart of the downpipe. So I guess it would be Header => Downpipe/Catalytic Converter => Tsudo Exhaust.
Yep. See the slip fitting there on the left of the downpipe? In this case, that attaches to the collector of the header, and then the 2-bolt flange bolts to the exhaust system.
The only thing I could think of that would be different is if he was talking about the first generation header/dp combo w/ the stainless steel header. I think that's the one OBZ uses.
Yeah - a lot of header/downpipe combos I've seen have had 3-bolt flanges between the two.
Discussion Starter #7 (Edited)
okay more questions here....
First im guessing the object outlined in pink is the part that slides into the bung (no pun intended) on the downpipe...
And also I was at the understanding that if I was to get headers, that I would need the SAI compatible, but after looking i didnt see a hose, the closest hose was this one v v v however it doesn't actually go into the header like the aftermarket ones do...and I DID have to attach the tube to the bottom side of my intake so I thought I needed SAI...???
or is the sai hose on the bottom side of the headers?
---------- Post added at 05:42 PM ---------- Previous post was at 05:04 PM ----------
bump?
The SAI pump is below the intake manifold.
---------- Post added at 05:44 PM ---------- Previous post was at 05:43 PM ----------
And you do not need a SAI compatible header. Just remove the SAI and have it tuned out.
1 - 13 of 13 Posts
