Hi People,
Installed glow lights about 2-3 weeks ago. Worked Ok until tonight: they flicker on/off and cant even turn off with remote. Is the remote sensor box under car maybe suspect?
Thanks!!
Your car is rejecting the rice-light implant.
J/K. Sounds like the sensor, but with the flickering it could just be a wire loose. I would start there. It's the easiest thing, then work up once you are sure all the connections are good.
Thanks, J. Looks like a good Sunday project is at hand. I'll let you know what happens.
