shiit they didn't have that 2-3 weeks ago when I bought the fe-5 suspension package!!! I bought B&G springs seperately though, so now my suspension setup is pretty much done. And they are indeed reputable, and that setup will make a big difference in your handling. Go for it man you won't regret it. I'm installing my setup next week!
I wonder how much drop you'll get with this suspension setup. How lo are pedders anyone know?
And for all you on fe5 (Tc) shocks/struts with lowering springs, how long will the shocks/struts hold out with the lowering springs? I'm assuming quite a bit longer than stock suspension since the fe5 is made to damp lower/firmer springs from the get-go.
see the suspension sticky.
doesn't answer the question about how how long my fe5 suspension would last while lowered.....
That's not a specific answer. It'll last longer and ride better than your FE1 stuff. There's no specific time frame.
Just depends on how you drive it.
figured as much. Roads here suck but I avoid all potholes and go slow over speed bumps. Bottom line is I'll be as prudent as possible on these roads, especially once my suspension is on. Thanks anyways for all your help will!
