1 - 8 of 8 Posts
I could really use a "how to" on geting throught the firewall I just need to run two small wires from the engine bay to the inside of the car. But I have no idea how to do it. Pictures would be great since I'm still a newb.
I'm wiring an engine bay light like coby7 installed but instead of using the mercury switch I'm installing a blue glow toggle switch inside the car by the dimmer control switch. So I have to run wire from the light to the switch and back to my wire tap in the fuse box. So I just need a hole big enought for four 18 guage wires.
If you look behind the underhood fuseblock You will see a bunch of wires going through the firewall. There's room in the armour for more wires, just punch a fish through, tape your wires to it and fish em through.
I kinda did that already, but I went behind the break. I was trying to feed it threw with the wire that was already there but that wasent working so I just pierced a hole next to it and it turned out fine all I have left is to connect the ground and plug the fuse tap back in and I should be done. Or if I did something wrong its time to start trouble shooting. Lol
Post up some pictures once you're done. We like pictures
Ok pictures, humm never done that, but ill figure it out. Ill get some daylight photos and some night time photos. Since it only 5 o'clock. It will have to wait a few hours. Lol
1 - 8 of 8 Posts
