1 - 20 of 22 Posts
You still under warranty? There was another post on this somewhere I just read yesterday. A guy had his car "pee" on his girlfriend when it was raining.
Not under warranty anymore.
It's not spurting out all over the place like the guy made it sound. lol
LOL ok, so your Balt is potty trained somewhat... I wonder if there is a drain plug under the body of the car? I've never looked into that but being that I live in Seattle, WA, I think I should!! :eek:h:
Sounds like either a drain plug or maybe a problem with the weather stripping around the door.
Im the guy whos car pees. I did a bunch of research and discovered its some issue with the AC. I found the TSB number and everything and it sounds exactly like whats going on with my car. I drove around today with the AC off and guess what? No leakage. Im gonna have to take it in for a warranty repair. :-/
Lol oh you're the guy.
Ok, I was wondering if it may be the a/c. I'll have the dealership check it out I guess. Will it cost for them to just check and see what it is you think?
[Not under warranty anymore]
My passenger side was doing this recently. Can't remember what the dealership said it was but I'll look to see if I can find my invoice and I'll post what they found later.
i had the same problem with my cobalt many times. took it to the daeler and they first kept telling me its not leaking, then after i kept going they then tried to blame it on aftermarket speakers? still dno what the problem is but i still get it from time to time. it sucks
Talk to your dealer about Technical Service Bulletin #050138016. This TSB is for "WATER LEAKING ON FRONT PASSENGER SIDE FLOOR OF VEHICLE, WATER BLOWING OUT OF VENTS (SEAL HEATER CORE COVER)." I recall reading elsewhere that the fix for this is to blow-down the line that drains from around the heater core as it may become clogged, and to replace the seal around the heater core. I am going to attempt to go to my dealership on saturday, but it may have to wait until next weekend while I am out of town and don't need the car. I will report back.
The leak in my car is just on the drivers side though.
Keep me updated though.
Thanks for the info Sindri.
I have this same problem and it is on both sides of the car in the front. I wanna say it is the door seals because it only happens when it rains. I'm not really sure what it is though to be honest.
Occasionally when I drive through constant rain for a decent amount of time, my floor behind my front seats gets wet. Stopped for awhile but I had it happen again but this time on the opposite side. Never had it wet in the front floor, only the back.
1 - 20 of 22 Posts
