Need to Sell! $525.00 for Both FREE SHIPPING!!!! Hit me up if interested!
This is a brand new genuine Exedy standard OE replacement clutch kit. This clutch kit contains all the necessary components to do your clutch replacement and is the perfect setup for any stock or lightly modified vehicle. Exedy Globalparts Corporation was founded in 1923 and its clutch manufacturing business and prominent brand name Daikin Clutch are known throughout the world for supplying quality powertrain products. Exedy supplies to all 11 vehicle manufacturers in Japan as well as many other vehicle manufacturers including Chevy. Exedy is the largest clutch manufacturer in Japan and their name stands for the highest in quality and performance.
* This complete clutch kit includes: Exedy Pressure Plate
* Exedy Clutch Disc (238mm, 14 spline)
* Slave cylinder with Release Bearing
* Alignment Tool
* Installation Guide
Fidanza Aluminum Flywheels are made using the highest quality, most modern materials available. The flywheel itself is made from 6061 T6 billet aluminum. It is CNC machined at a constant surface speed for durability and finish. The friction surface is very special. Fidanza uses a 1050 high carbon, alloy steel. It is incredibly durable, allowing the user to use just about any clutch disc material available. The friction plate can be machined or replaced as needed. The plates are secured with 16-20 hardened aircraft quality screws with self locking nuts which prevent any warping. Fidanza uses hardened ring gears that are swarted to the flywheel with button head screws that are counter board between the flywheel and ring gear to prevent any possible slippage. The mass at the center of the flywheel is retained for strength, but the mass at the outside is eliminated for optimum performance.
* Ultra Light and weighs only 8.5 lbs
* SFI approved 2 part design with replaceable clutch contact plate delivers the highest quality and longest service life of any flywheel available.
* Fidanza flywheels work with every clutch including Exedy, ACT, Fidanza, Clutchmasters, and other OEM clutch kits
* Fidanza Part number: 198201
* Made in the U.S.A.
