2009 Cobalt 4 door non ABS plain Jane 2.2L auto. 58K. Make’s a loud noise that sounds like a tire with the tread separating, moved the tires front to back no change. From the beginning, determined noise was from right front wheel so I replaced the bearing yesterday after the previous first step but that didn't fix the problem. Loud humming noise from front wheel or in that area, symptoms are; a loud humming noise at full song by 30 MPH from the passenger side (right hand) front wheel area. I have a sense of vibration but the steering wheel does not shake or vibrate. Bearing replacement didn't change the noise a bit, If I whip the wheel to the right noise subsides if to the left noise gets a little louder. The car drives straight, no clicking like a bad Constant Velocity Joint when turning either way. At speed (30MPH) I put it in neutral and there is no change, noise is still there while coasting, applying the brakes while coasting in neutral or in gear just slows the car doesn’t cause the noise to change.
Is there another bearing inboard on that side at the transaxle?
Don't know front wheel drive that well.
Wheel bearing noise is very hard to pin-point from inside the car because it is all linked with solid metal. Noise that would appear to be coming from the right wheel could very well be coming from driver side. The best way to determine which bearing is bad is to put it up on the hoist start it up and with the stethoscope listen to each hub.
You were saying it get's louder when you turn left that is because all the weight falls on driver side bearing and it will get louder turn right all the weight falls on passenger bearing and you get less noise. This points to driver side bearing. Don't feel bad you won't be the first to change wrong bearing, like I said very hard to tell from inside the cabin.
Chevy Customer Service
I'm not sure of what your plan of getting this looked into is, but if you decide to visit your GM dealership please let me know as I would like to available to help in any way I can. I understand that this isn't always an option, however.
Best,
Sarah
GM Customer Service
Thanks, I have a stereoscope, will put the front up on jack stands and let it idle in gear to check it out. When I resolve this I’ll post up here to help the next person out, don’t like dangling unresolved issues.
Don't forget to pull the parkbrake lol
I had the same issue, I have no ABS though, but surely enough, I added one new wheel bearing and my noise went completely away, its such a nice feeling when you finally change that bad bearing, heavenly.
