1 - 19 of 19 Posts
I have an extra set, still in the box, of 5.25" and 6x9" speakers for sale, both are the correct sizes for our front and rears.
Specs:
5.25" 2-way Kickers, 135 watts - $50 + shipping ($100 at Crutchfield)
Peak Power 135 Watts
RMS Power 45 Watts
Sensitivity 90 dB
Frequency Response 45 Hz - 21 kHz
Impedance 4 Ohm
Mounting Depth 2.25"
Cut-out Dimensions 4.56"
6x9" 4-way Pioneers, 440 watts - $80 + shipping ($140 at Crutchfield)
Peak Power 440 Watts
RMS Power 80 Watts
Sensitivity 92 dB
Frequency Response 30 Hz - 31 kHz
Impedance 4 Ohm
Mounting Depth 3.25"
I have these exact speakers installed in my car, and they sound great, without an amp. Need any more details, just ask. I would not be against taking a little road trip to meet halfway to save on shipping costs.
Edit: $110 if you buy them both together.
Discussion Starter #7 (Edited)
do u need an amp for these kind of things??? and where do u live
No, you don't need an amp. I'm near Charlotte, NC.
hmm, i wonder what a '97 cavalier coupe front and new size are cause the ones in it suck(stock most likely). Bump
a '97 Cav is 4"x6" front and 6"x9" rear deck. The 5.25"s should fit in the 4x6 slot, you would just need the right kind of mounting plate.
Edit: 5.25"s will fit front, with this - http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=260355329319&rvr_id=&crlp=1_263602_263622&UA=WVF?&GUID=ca74de631230a0b58377ec67ffe016af&itemid=260355329319&ff4=263602_263622
I'm highly interested but would like to see pics.
Discussion Starter #11
Are my pics not showing? I put 4 up there, maybe I did it wrong.
Anyways I'll edit and add detailed specs, and redo the pictures.
---------- Post added at 09:06 AM ---------- Previous post was at 09:03 AM ----------
I must have uploaded the pics wrong, I'll redo it and add more detailed specs to OP.
Does the coupe and sedan have different size door speakers. Everywhere I looked it shows 6 and 1/2 for the doors.
Discussion Starter #13
I don't know if sedans are different than coupes. I do know you're probably seeing 6.5" because you can technically fit 6.5", you just need the right adapter. The coupe size is definitely 5.25".
Yea , everywhere I researched and even the local audio shops say 6 1/2. I really do not like the "technically" term, as "technically" I can put 6x9 or larger in the door if I wanted to do major mods.
PMed
1 - 19 of 19 Posts
