Ive got two sets of Coolermaster Aquagate duo viva water cooling systems. Asking $50 a piece
This is the msi overclocked edition with a nice fan and heatsink. Solid capacitors for overclocking. 640mhz core clock and 1986mhz memory clock from the factory. Asking $75
here are the specs from newegg Newegg.com - MSI R4850-2D512-OC Radeon HD 4850 512MB 256-bit GDDR3 PCI Express 2.0 x16 HDCP Ready CrossFire Supported Video Card - Desktop Graphics / Video Cards
Zalman 9500 cpu heatsink with 92mm fan. Asking $25 Newegg specs. Newegg.com - ZALMAN CNPS 9500 AM2 2 Ball CPU Cooling Fan/Heatsink - CPU Fans & Heatsinks
OCZ Platinum DDR2 1066 memory 5-5-5-18 timings Asking $75
Here is the newegg link for specs.Newegg.com - OCZ Platinum 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 1066 (PC2 8500) Dual Channel Kit Desktop Memory Model OCZ2P10664GK - Desktop Memory
Windows Vista Business 32 bit Asking $75
Nice deals you have here. If I weren't about to order a few different items on Newegg, I may consider your hsf and video card. Wish I knew more about liquid cooling, I'd consider that as well.
Discussion Starter · #3 ·
you can get them from me cheaper :bigsmile:
You don't have what I'm purchasing though...I don't have use for memory with a speed higher than 6400...that HSF won't fit in my case, plus, forget Vista...straight to 7 from XP for me.
Good luck though.
Liquid cooling is l33t if your running a nice CPU and matching graphics card. Also some cases don't have room for a lot of cooling fans like the new Coolmaster HAF 932 *drools* so liquid cooling is more efficient.
I've never used it because water around a pretty pricey PC...just wouldn't work in my mug.
