1 - 12 of 12 Posts
Our fuel filters are good up to 100,000 miles.
1. relieve fuel system pressure
2. Raise vehicle and support on jackstands.
3. Clean fuel filter fitting on outside ot pevent debris from entering fuel system.
4. Disconnect fuel lines at both ends of fuel filter. Watch out excess fuel. It will spill out.
5. Remove fuel filter. Also note the direction of the filter is installed for proper installation of new filter.
6. Install new filter, reconnect lines, and make sure the fittings are attached securely. Star engine and check for leaks.
nice, thanx
If you need i can go into more detail. I can Copy it from the Haynes Manual if you need it.
1 - 12 of 12 Posts
