How do you get the lines off. Mine has what looks like push in releases on the sides on the 2 hoses and no matter what I do I can't get them off. On the other side going to the motor is a blind attachment. my new filter has squeeze ends but the existing there is nothing visible.
you need a fuel line disconnect tool. on the fuel filter, it's different, you press both tabs, push the fuel line towards the filter and then slide it out. with the fuel line connecting to the fuel rail you use a disconnect tool. same deal. push it towards the fitting, then push the tool in, then pull it off.
