Hey guys I wanted to install new fuel pump but want to upgrade to something better. Not sure what to look for or where...
Need a little guidance
Say Hippy.. what engine power do you want to drive with your fuel pump?
Any thing over 300hp?
Seems the stock Cobalt replacement setup will handle what you need. Now if you want, you can splice into your existing fuel pump/sending unit assembly a higher volume and keep the fuel pressure your system expects. Lots of work with little or no benefit except for loosing some weight........out of your pocket.
Try any one of the on-line parts houses and go shopping. One of the generic parts shops I use is RockAuto. Give it a try, there are several that have on-line parts lookups. Now for the 300-600hp - and up one can start with a place such as Summit.
