Driving home one night in the rain my friend decided to turn on the hazard lights... Once i noticed i quickly pushed the button to turn them off. But they didnt turn off. So i took apart the dash and just unplugged the switch. Is there any fuse I can take out that is connected to something i do not need? Because there is not a fuse for the hazards unless i completely missed it. I really don't want a circular hole in my dash without the hazard button. I figured it would be easier just to take a fuse out.
Just get a new switch can't be that much and you already have the other one out so why not just replace it. I'm sure you can pull one out of a junk yard for just a few bucks.
pull the fuse for turn signals. that should tell you. i would guess its that one.
And if it is the fuse for the turn signal how can i to get it from stop flashing? While still having turn signals
id start by checking the switch. the problem is probably there if your turn signals work properly. like viper said, shouldnt be that expensive. maybe a pita to take out though. hopefully not a bcm problem. you could take it to a dealership and have them scan the bcm for codes first i guess.
