1 - 11 of 11 Posts
Hi!
So yesterday I forgot my iPod in my car going to work and it has been charging for the whole time(about 6h30), I don't know why the car power didn't turned off when I opened the door but anyway.
Now my speedo numbers(20,40,60 etc) and Rpm numbers on my dash, console lights for button (RRW, Defog, etc) and parking lights don't work.
It smelled shit so I said well I burnt a fuse so today I decided to look at this and I found the burnt fuse. It's the 15a PRK Lamp. I changed it against another 15a fuse in the space fuse lot and everything worked fine.... for 15 sec.
Guess what? The new fuse burnt also! So I guess that anytime I'll put a new fuse it will burn. I checked every single other fuse if another was burnt and it was the only one. I went at the garage where I bought my car and his mec isn't there for a week and I don't want to go to GM as it will gost me 250$ of labor. So can anyone help me out??
Vehicule:
Cobalt LT 2 Door 2007
Thanks for all the answer!
I don't think the iIpod is/was the problem, I keep my Iphone plugged in while I'm at work, ( I work 12 hour days) and have not had any problem, no battery drain, no blown fuses. It might just be a coincident that your fuse blew when your Ipod was plugged in.
Maybe, but now the car won't start... FML.
BUMP!
Here's a video, a think I activated the anti-theft but I don't know how the f*** I activated it and how the f*** to desactivate it... Someone help me out please!!!
Maybe try removing the negative connection on your battery and leaving it for ten mins then trying. No idea if that would work, but that's what i would try.
Well I towed it this afternoon, thanks anyway. My car is still under dealer warranty so I think the best thing to do is to put it on their hand, not mine.
If you have second set of keys, try to use that one and see if it still does it. Good idea to get it serviced and looked at. I had that happen to my wife's Kia Optima. Used the second set and it worked fine. Oddly enough, our keys do not have a chip build in (at least not the 2006), so that shouldn't have tripped it (unless your key is so work that it thought it was not the original key).
I've heard about this somewhere. The car would not recognize the key it would enter in anti-theft mode. The problem is that I only got one set of keys and yes my key are chipped. Anyway, everything should be fine by the end of the day. The dealer said that this could be something with the electric wiring touching something wrong(like a part of the body or something else).
I would guess you have to much amperage causing you to blow the fuse. Actually determining this would take a little knowledge on how to use a multimeter and just make sure you have less than 15amps showing up. That would have been my suggestion good luck dealer! :)
soulsurfing, I have a 2006 LS and my keys are chipped. I have a regular key in a hide a key that only will open the doors, but will not start the car. 2006 do have chipped keys.
Discussion Starter #11
I just went at the garage to see what was going on with my car: amperage is good, this is now fixed. He now need to solve the car lock emblem that make my car won't start.
He checked if the computer had the code problem stored and nothing appear.
He changed the ignition and it did not change a thing.
He deplugged the batterie for 15 mins reset the lights and nothing happened, still the car lock emblem.
2 more thing to check:
Wire that goes the link between fuse and other things.
If that fails it's the computer...
1 - 11 of 11 Posts
