Just a simple question as I can't seem to find a direct answer anywhere. I am ordering a part that requires me to specify if the fuse inside the cabin is a standard fuse or a mini fuse. Could anyone tell me what size I have? This is for the inside cabin box. -Thanks
Mini, I think they are mini everywhere in the car
Sent from my EVO
What do you call inside cabin box? Do you mean the "BCM" fuse block.
like this...
If yes they are mini fuses
---------- Post added at 07:51 PM ---------- Previous post was at 07:50 PM ----------
Sent from my EVO
Maxi in trunk for BCM
---------- Post added at 07:54 PM ---------- Previous post was at 07:51 PM ----------
Also a few square ones like number 29 in BCM drawing. Some square ones in the underhood fuse block also.
Ah I think I never seen fuses in the trunk my bad. I I was half right
Sent from my EVO
Discussion Starter · #6 ·
Yes Coby7, The BCM you helped me with before. I also had no idea about the trunk ones. Thank you both.
50 amp fuse seen here in red.
