1 - 9 of 9 Posts
i believe it is on the passenger side and you have to remove a panel to get to it by where your left foot would be.
It tells you where it is and how to remove the panel in your owners manual
what color light you installing? i have red footwells from streetglow i installed there. doing the backseat lights tomorrow actually. so if you need any help, let me know
Did you not read the car manual? *bangs head on table*
from what im to understand you just jam it in with the fuse...
there is something you can buy, all i did was find the fuse i wanted to piggyback off of, pulled it, stuck the wire in the side of that hole then plugged the fuse back in on top of it. it works fine. if your installing lights make sure you plug it into a ignition fuse, not a battery fuse. try fuse 15 or 20 i think. i used the wipers.
1 - 9 of 9 Posts
