Figured I'd post it since I'm not sure it's common knowledge...
09 Cobalt LS, 2.2 Ecotec LAP. I'm investigating some P0010 problems and dug into the wiring a couple weeks ago to check everything out. The wiring is not the issue (I suspect a bad oil change record) but I discovered something rather interesting anyway. The slot marked "Engine Valve Solenoids" in the fuse box is actually a blank; i.e. putting a fuse there will not connect anything. The VVT solenoids are actually powered off of the same circuit as the sidemarker bulbs (labeled "parking lights") on the fuse box cover. This circuit receives its power from a miniature relay soldered onto the printed circuit board inside the fuse box. That relay, in turn, is controlled by the BCM.
I didn't believe it at first, but it seems the wiring was just a bit of an afterthought at GM in this case...
