1 - 8 of 8 Posts
Alright, I finally got my ZZP headers and downpipe. But I failed to realise that the headers and downpipe I ordered didn't come with gaskets.
I've looked on ZZP's website, but I can't find anything on what gaskets I need. I settled on the shorty headers with the 3" opening and the 3" ZZP downpipe with the 2.5" exit. I just need to know what gaskets I need for the header to engine section and headers to downpipe section. Can anyone give me any idea on what I need?
The shorty header has the 3-bolt flange, yes?
If so, then you can use stock replacement gaskets for the manifold to downpipe and the downpipe to catback, since both are considered stock replacement parts.
You could just use high heat rtv silicone.
Cobalt Lower Exhaust Manifold Gasket 15235773
Converter to Exhaust Pipe Gasket 15231157
I know the top one should fit, the second one i am not sure about
Looks like it should. Not sure if the part numbers are the same between the 2.2/2.4 cars and the LSJ.
I cant remember off of the top of my head but i will try and check when i can get to my computer.
Looking on Rock Auto, it appears so.
Fel Pro numbers:
61362 (downpipe to header)
61440 (downpipe to resonator/exhaust)
Yes, the shorty headers have a 3" flange. The downpipe is 3" in diameter until it gets to the exit where it bolts to the exhaust and then it goes down to 2.5".
1 - 8 of 8 Posts
