1 - 20 of 106 Posts
I have the manuals for 2005, 2007, and 2009. Along with a listing of GM specific trouble codes.
If you need info or pictures I can try my best to find it through out the plethora of information.
If you do need info, please be specific about what you are in need of. Thanks! :)
Interesting. If I decide to do a radio/steering wheel swap to the 07 stuff, I'll have to hit you up for the wiring diagrams.
Discussion Starter · #5 ·
I was just skimming thru the info for that....I think you would be better off if I just get you copy for '05...LMFAO...there's so much info to go thru...
If I would do such a thing, I'd need the diagrams for both the 05 and 07 since It would require a repin for that to work.
It is a project I'm probably not going to get around to accomplishing since it requires me to buy an airbag module. They're not exactly cheap.
Well... I might not be needing the diagrams just yet... I'm about to blow about 500 on seats.
ok thanks, im not going to do till next friday, also i like this new cobalt, and would like to know what is better Dexcool, or ? just the green stuff?
Discussion Starter · #15 · (Edited)
OEM (Factory) Coolant is Dexcool.
---------- Post added at 09:52 PM ---------- Previous post was at 09:33 PM ----------
Here is a link to download the PDF for the "engine cooling system"
Engine Cooling PDF
1 - 20 of 106 Posts
