101 - 107 of 107 Posts
I have the manuals for 2005, 2007, and 2009. Along with a listing of GM specific trouble codes.
If you need info or pictures I can try my best to find it through out the plethora of information.
If you do need info, please be specific about what you are in need of. Thanks! :)
Looking for manual on a 2008 Cobalt 2.2 liters, manual transmission
Hello, first post here, kind of very unique question. The little grommet, bezel, what ever you call it around the passenger door lock, I can't seem to find a replacement nor can I find the part number to search for. Can anyone give me a hand? Thank you so much.
Can u send 2007 cobalt . having problems with codes p1682 and u0101.
XFE hasn't been around in some time. Your best bet is to start a new thread, list the car your driving, any codes, and describe what's happening.
Can you help me with a U0101 Code I think it may be a bad ground after trying a handful of other things and not having any luck so if you could send images of grounding points in the engine bay would be nice along with the manual
i have a 2007 lt,
I have a 2007 lt, having issues with o2 sensor heaters, ive traced 12v to each sensor, now trying to trace where the grounds go? any schmatics on that would be a help, as well as ground locations. i've found two on the engine that had corroded off wires, but after fixing i still have same issue.
