Reading a couple threads on it and it seems like it's in a sleeve kit with eibach springs. Some use them on koni struts/shocks. How? Idk
This from a css member
There are some minuses to sleeves but if you can live with them then they can fit specific needs. I don't run them because they tend to be not very street friendly unless you get shorter springs and add a helper or tender spring. Also they are not really meant to be adjusted by height. Proper use should have them adjusted according to corner weight and spring preload. If none of this makes sense, you shouldn't even be considering them.
