After an increase in frequency in the loss of headlights in the Wife's Cobalt, I started to investigate what the cause could be, given the most common reasons. I'd discovered that the Dc voltage off of the regulator was a tad bit high, though for most everything on the car, tolerable, possibly even for the headlamps, except that these are daytime running lamps so they see a lot of hours, coupled with the 15 volts and this means a short life span.
Instead of replacing the alternator's regulator i'd decided to go a different approach and went with LED's for the headlamps. Specifically choosing this model as they have regulation from 12-24 volts which would solve my issue. As the Cobalt doesn't lend itself to modifications, I had to do some work to get these in, but nothing crazy. Turns out they really do work good. We will find out how long they last now. Wife approved.
Daytime running lamps run on a reduced voltage of about 10.5 volts unless the wire coil resistor shorted out like it did on my 07.
