So the halos fit in but there is a gap between the rubber part on the top of the headlights and the hood and i can tell its letting water in and getting to my intake like it is not sealing right is there anyway to maybe fix them help them seal better
To clarify...you're talking about aftermarket projector headlights? Because 'halo's' are just the actual rings that light up...like ones you can add inside custom retrofits. Totally different story...but if I am right and you're talking about the whole headlight, then it should fit pretty perfectly into the headlight bracket. If not, there's a chance you're fitting them on wrong. Try playing around with the wiring in back of the headlights to get more space. Make sure the holes for the two bolts line up.
