Did someone have a complete procedure for removing the head cylinder and changing the gasket.
Thank you
remove the valve cover, front cover, timing chain, intake manifold, exhaust manifold, cylinder head
you will need to get new coolant,oil and filter, crank bolt, cam gear/sprocket bolts, head gasket kit with bolts which also may or may not come with intake gaskets, valve cover gasket,intake and exhaust gaskets
i would replace your timing chain with new and change the tstat while your there
saw your other post about cracked manifold - just replace with a gm one or zzp offers i believe a exh manifold for a 2.2/2.4
