1 - 1 of 1 Posts
Does the bcm have a ground, the guys just threw in the bcm in unbolted is there a ground not attached on the module? the car is flinging the same codes after being fixed. the codes are p0650 mil malfuntion, p0700 trans control, p0717 input shaft speed sensor a no signal. the trans control module has been replaced, the speed sensor as well. This must be an electrical problem. Any ideas????:push:
1 - 1 of 1 Posts
