05 LS with 115k
I have a thump sound whenever I start to move forward and again when slowing down. Sounds like something is moving when I accelerate and goes back when slowing down. Only momentarily not continuous.
If I have the car parked in drive on the ground and rotate the front right tire as far as it will go by hand forward and back I can feel the thump can not determine where it is coming from. Any suggestions as to where to start would be appreciated. Wheel bearings were replaced at 100k
Sounds like lower control arm pancake bushing!
Once I got the car jacked up it was the brake rotor, the 4 bolt holes were worn, the rotor would move about an 1/8 of an inch either way wearing into the wheel studs. New studs and rotors are on the way.
This means your lug nuts weren't torqued properly.
For alloy wheels yes, 110 for steelies
