TurboByGarrett.com - Chevrolet Cobalt
The Garrett® Chevrolet Cobalt Turbo Kit is for the 2.2L Ecotec engine for LS coupe and sedan model years 2005 and above. A GT2860RS "Disco Potato" ball-bearing turbocharger and all of the necessary components are included to complete the installation in your own garage!
Chevy Cobalt LS and LT coupe and sedan models with the 2.2L Ecotec engine
Model years 2005 and later
Garrett exclusive ball-bearing turbo for unbeatable response, efficiency and durability.
Four trim levels are available, from a complete solution to a tuner's dream.
Garrett® Turbo Essentials Kit (P/N 772764-3)
Garrett® GT2860RS Turbocharger
Cast turbo manifold
Cast down pipe
Gaskets and fasteners
Garrett® Turbo Essentials Plus Kit (P/N 766621-3)
Essentials Kit items
Oil and water lines
Attachment hardware
Garrett® Turbo GT Tuner Kit (P/N 766621-2)
Essentials Plus Kit items
Charge air cooler
Charge air cooler plumbing
Hardware
Garrett® Turbo Alpha Kit (P/N 766621-1):2005-2006 Manual Transmission Only
GT Tuner Kit items
Engine Control Unit *
Larger-than-Stock Fuel Injectors
Garrett Brand Boost Gauge
* Once the re-flash tool is used on a particular vehicle, the tune is non-transferable. The scan tool is VIN-specific and only works with the first VIN that is entered. The calibration of the tool is locked to ensure the integrity of the calibration. Use of a piggy-back system or changes to the calibration may result in engine damage.
PERFORMANCE COMPARISON
Stock Garrett Turbo Kit
HP 136 @ 5500 rpm 198 @ 5000 rpm
Stock 139 lbf/ft @ 4000 rpm 219 lbf/ft @ 4000 rpm
