1 - 12 of 12 Posts
Hey guys, I was hoping to get some friendly input on what you guys think I should do about removing these unsightly scratches...
Take a look...
As you can see, I have some pretty serious cosmetic damage to my car's body. Any input you guys have that will help would be greatly appreciated. Thanks in advance.
Respect,
AdrenalineMitch
Some of my scratches look the same, in for advice
Sent from my PG86100
The bumper scratches won't be easy to fix, the paints all gone. Now the other scratches can easily be taking care of by a rotary buffer but if you don't know how to use one I suggest taking it to the pros. Good luck!
Sent from my iPhone using AutoGuide.com Free App
I have the same problem on my bumper. Big gash due to the accident. No idea how to fix it.
I have to replace my whole trunk next summer due to the accident as well.
Good luck with the fix though.
I've got something similar on my bumper. I haven't found a cheap or easy fix for that yet. A shop quoted me about $275 to fill and paint, and that was too high for me.
There are 3 certain things in life: death, taxes and getting rear-ended by someone who can't drive. The latter should get your bumper back to A1 if you can wait for it.
Hey all, this topic has been inactive for a while but I'm still in the same position with my severely scratched up bumper.
I was looking online a little, and I came across dupli-color: perfect match. I figure if I use the primer that goes along with the duplicolor: perfect match and then repaint it with the duplicolor paint I might be able to fix this issue.
Anybody out there ever used these products and have any friendly advice/input on whether or not I should do so??
Thanks in advance!
AdrenalineMitch
I used scratch off on a scratch that was similar to the ones you have that aren't so deep. It didn't remove them, but sire helped with making them a lot less noticeable
2005 cobalt base model coupe
Levee
Ok, as far as the bumper, you're not going to be able to do anything less than use paint (weather touch up or a whole re-paint). If you use the touch up you will need to put it on there, and re-clear coat it (the whole bumper to it's even), and re-wax it. That's the only way to get rid of the scratches on the bumper.
As far as the others, most of those can be taken care of with a good wash/claybar, and re-wax (a couple layers of wax that is). If the scratches are deep, I've found a little trick. ATF fluid. Put some on a rag, wipe over the small knicks and scratches, and it will "fill in" the issues. Dry it completely (basically make sure there isn't any oil residue left), and do a couple of good layers of wax on top of it. will make it look 10x's better than before.
Just my $.02
1 - 12 of 12 Posts
