I recently bought a 06 Chevy SS (160mph) cluster for my 06 Chevy cobalt LT, (120mph). After install, the DIC didn't want to clear pop up messages or scroll through the functions. To make sure I didn't damage anything, I reconnected the original, and it worked fine. I was under the impression that all 06's match to 06's without any issue. Anyone know a fix to this?
I found an ss cluster on eBay that I was looking to buy. He had a few pictures of it so I cross checked the pictured part number and found out he hadn't listed it properly either. Seems like a common problem on there. I always confirm the part number with the seller before purchase now.
Yup that's exactly why you have no sounds.... 07 and up the blinker and sounds come through the drivers side door speaker. 05 and 06 it comes from the guage cluster.
Bumping this for a related question. I pulled a cluster (white faces/ 140mph) from a Cobalt sedan at a junkyard today, but it wasn't an SS. Anyway the numbers on the sticker are 15246265 and *506265A051150191* (and something else that says 3ACAR). It also has the speaker on the back, so this must be an 05-06 cluster. I assume this will this not work then, if I put it in my wife's 2009 2LT sedan? I know I wouldn't hear the turn signal, but what about everything else?
looks like its for 05-06. it for sure won't work in anything above 06. Seems like i read somewhere someone tried it and had problems with the fuel gage and speedo.
Gauges should work fine with any cluster. DIC should work with 05-06 (interchangeable), 07 (only), 08+ (interchangeable). At least that is what I found out when I was looking for my G5 GT cluster a few years ago. (mine's an 07 obviously) I actually didn't know about the speaker on the 05-06 though. Makes them quite easy to identify!
Hmm. So based on what you said I would need a 2008+ SS cluster in order for it to work in a 2009 2LT? Hard to believe a 2007 would only work in another 2007 model... I thought the separation was 05-6, and 07-10. Why would GM change the cluster so often? I guess they did, if what this guy says is true: http://www.yourcobalt.com/forums/new-member-introductions/23709-here-learn-3.html#post496079
