1 - 10 of 10 Posts
so i want to seal up my gen 4 headlight because it always condensates.
i have to be somewhere in a bout 6 hours. is there anything i can use that will fully cure and ill be able to put my light back in my car so i can leave?
some 2 part epoxys (sp?) are quick set/dry.....go to ur local auto parts store and ask em, a friend of mine used a 2 part epoxy to fix a boat motor cover and it set in like 45 min.
yeah they have that at walmart.
how long would it take to fully settle tho?
i want it to be fully sealed so i can put my light back in
Hot glue. and wat you can do is. put hot glue all around it and put it in the over at 200* for about 5 mins and it should heat the glue and give it a better seal. work but remove everything first or bulbs will break. Or use. Loctite instant mix expoxy quick set 5 mins.
not putting my headlights in the oven,
cant afford to break them
i think i have a heat gun but its not a heavy duty one
isaw some stuff at walmart i was going to buy a while ago it was epoxy with 2 sides to make it come out. maby that will work
but i want something that will dry quick. rtv silicone isnt that great because it takes forever to dry and it drys jelly.
honestly no matter what you use, if you dont throw them in the oven you probably wont get a good enough seal
oh well i think the reason my other lights didnt hold well with the silicone was because i only did the bottom
im not putting my lights in the oven
so could i get that epoxy and just use that?
Unless you plan on never having to open the lights, just use sillicon sealant.
Also, I highly reccommend getting sillica gel packs and putting them in your headlight if you have a spot to do so. That'll suck some of the moisture up.
Yea i got some of the epoxy stuff but couldnt open it correctly because the directions made no sense. I guess ill have to get different type of silicone. Problem is im always out so there is never a time i can leave my light out for 24 hrs to fully dry
1 - 10 of 10 Posts
