Hey guys! I purchased my Cobalt SS SC about 2 weeks ago. I had to fix a few things so I had not got to drive it a whole lot. One thing that I have noticed is that it seems to idle high. It wants to idle around 900rpms when warm which I feel is high. Driving back and forth to work I've noticed that if you throw the car in neutral and coast to a stop, the idle will hang around 1800rpm until you almost come to a complete stop. You will be coasting up by the cars at the stop light and as you almost come to a complete stop, it will drop down to around 900rpm. I haven't hooked my scanner up to it to monitor TPS to see if the TPS sensor in the throttle body is screwed up or not. Any thoughts?
900 really isn't that high, I think mine idles right around there...but I haven't driven it since November, so I don't really remember. :laugh:
What about the coasting idle? That part is pretty annoying. It sticks to around 1900 when coasting and it drives me insane.
1900 is high...is it that high when you just clutch-in and when you shift to neutral?
Yeah, it's like 1800/1900 somewhere in there. Does it if you push the clutch in or throw it in neutral. I do believe that is only if you are higher rpm than that when you shift. It seems to just hang there....Once you come down to 2-3 mph it drops and idles like normal.
Based on a quick search on "the other forum" (CSS.net), it sounds pretty common with the SS/SC to have a high idle when coasting, with no real explanation why.
Probably all the more reason to engine brake, haha.
